Metric Washers In 2,000 Materials
An online search tool lets users select the unit of measurement, material, designate inside/outside diameters, and thickness range for metric washers. Washers are available in ODs ranging from 2.03 to 130.55 mm and a variety of IDs and thicknesses.
Over 26,000 nonstandard flat washer and spacer sizes with over 2,000 commonly specified and difficult- to-find material options are available. Metallic material options include low-carbon sheet steel, various spring steels, stainless steel, aluminum, brass, and copper and nickel silver. Nonmetallic options include ABS, acetal, polyester, nylon, MD nylon, polycarbonate, fiber, polyethylene, and various NEMA-grade laminates.
Boker’s Inc.
3104 Snelling Ave.
Minneapolis, MN 55406
(800) 927-4377
