Stepper-motor drive module
July 19, 2012
The DCM4826X stepper-motor drive module is a bipolar two-phase chopper drive rated for a 12 to 48-Vdc input voltage and a continuous output current rating of 2.6 Arms (3.68-A peak) per phase
The DCM4826X stepper-motor drive module is a bipolar two-phase chopper drive rated for a 12 to 48-Vdc input voltage and a continuous output current rating of 2.6 Arms (3.68-A peak) per phase. For use with rotary stepper motors or stepper-motor-based linear actuators, the unit can be configured for full step, half step, or microstep (1/4, 1/8, 1/16, 1/32, 1/64-step size).
The module’s mounting plate measures a 64 × 60mm (2.5 × 2.4 in.) with mounting hole center-to-center distances of 52 × 38mm (2.0 × 1.5 in.), respectively.
Haydon Kerk Motion Solutions
1500 Meriden Rd.
Waterbury, CT 06705
(203) 756-7441
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
