Hygienic servomotors
July 19, 2012
The W Series IP69K-sealed hygienic servomotors feature an all-stainless-steel, round housing design for long life and reliable operation in harsh food, beverage, and pharmaceutical applications, even with frequent high-pressure washdowns
The W Series IP69K-sealed hygienic servomotors feature an all-stainless-steel, round housing design for long life and reliable operation in harsh food, beverage, and pharmaceutical applications, even with frequent high-pressure washdowns. The unit’s innovative venting system eliminates the need for machine builders to supply compressed air to the motor, and a 3 and 6-m standard flying lead option eliminates the need for intermediate cables.
The motors use high-grade stainless steel for all external and internal metal components, foodgrade bearing grease, a food-grade shaft seal, and a laser-etched nameplate. The units come in 16ƒ frame/stack combinations, deliver 80-Nm continuous torque and 390-Nm peak torque at speeds to 7,500 rpm.
Kollmorgen
203A West Rock Rd.
Radford VA 24141
(540) 633-3545
© 2012 Penton Media, Inc.
