Pressure sensors
The new Model IP pressure sensors are CE certified and come in common pressure ranges (5 to 10,000 psi and 0.5 to 700 bar). IP sensors include temperature in its Total Error Band (TEB) configuration, improving measurement confidence and eliminating the need for supplementary calculations. Models IPG1 and IPG2 offer accuracies of 0.15 % and 0.25%, respectively. They are compatible with many liquids, chemicals, and gases and are designed for demanding industrial environments with temperature swings or pressure spikes. Typical applications include heavy-equipment monitoring, process and factory automation, and testing.
Honeywell Sensing and Control
2080 Arlingate Lane
Columbus, OH 43228
(800) 848-6564
