The NITRA line of pneumatic products has been extended to include air-pilot and manual-control valves. The AVS-5 Series now includes single and double-pilot directional control air-pilot valves, offering spring return or center-closed operation. All are body ported five-port (four-way) spool valves available in 0.12 to 0.50-in. NPT port sizes with flow coefficients from 0.67 to 2.79. Manual valves in toggle- style hand lever, push-pull, and rotary-style hand lever models have aluminum-alloy bodies, 0.12 to 0.50-in. NPT ports, and flow coefficients from 0.78 to 5.29. Models are available in two or three-position detented styles.
AutomationDirect
3505 Hutchinson Rd.
Cumming, GA 30040
(800) 633-0405
