ISO air cylinders
June 15, 2012
Extruded body, ISO 6431-compliant air cylinders have standard magnetic pistons in seven bore sizes from 32 to 125 mm.
Extruded body, ISO 6431-compliant air cylinders have standard magnetic pistons in seven bore sizes from 32 to 125 mm. Stroke lengths are to 1,000 mm. Adjustable air cushions at both ends and machined male rod threads with jam nut are also standard. The hard-anodized aluminum cylinder tube ID and OD ensures corrosion resistance and long product life, and lubrication is not required. Optional position sensor mounting brackets fit over any of four extruded housing rails. See Catalog #FAQR-09 for complete specs and prices.
Fabco-Air
3716 NE 49th Ave.
Gainesville, FL 32609
(352) 373-3578
© 2012 Penton Media, Inc.
