Rugged circular connector
June 14, 2012
The new Circular High Density (HD) connector line is a low-cost alternative to 38999 and other circular connectors for rugged non-Mil Spec applications.
The new Circular High Density (HD) connector line is a low-cost alternative to 38999 and other circular connectors for rugged non-Mil Spec applications. The connectors offer ease of push-to-latch/pull-to-unlatch mating as well as the advantage of blind mating into small spaces that normally requires clearance for hand tightening to mate.
Other features include scoopproof, blind mating; operating range of –65 to 125°C; durability of 1,000 mating cycles; five shell bodies ranging from 14 to 27-mm diameter; panel-mount receptacles; IP68 rated with potted, solder cup or PCB termination; 96-hr salt-spray exposure; withstand 37 g’s of vibration and 50 g’s of shock; cable-attached plugs and receptacles; up to 40 signal contacts; and up to 20-A current rating.
TE Connectivity
1050 Westlakes Dr.
Berwyn, PA 19312
(800) 522-6752
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
