Miniature diaphragm pump
June 14, 2012
The 1410 Series dc diaphragm pump measures 3.3 × 1.2 × 2.1 in. and is designed to work with a range of motor options and several design configurations, depending on the life requirements and specifications of the application.
The 1410 Series dc diaphragm pump measures 3.3 × 1.2 × 2.1 in. and is designed to work with a range of motor options and several design configurations, depending on the life requirements and specifications of the application. The pump features a low sound level, weighs 0.4 lb (180 gm), and is EMC suppression qualified to EN55011-B on some designs. Maximum flow is 4.3 lpm, with a maximum pressure of 27.5 psig/1.9 bar, and a maximum vacuum of 22.0-in. Hg.
Thomas Div.
a Gardner-Denver Co.
1419 Illinois Ave.
Sheboygan, WI 53081
(920) 457-491
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
