The MPC and MPX quick-connect lines now include back-to-back body adapters and sanitary inserts. Available in polycarbonate and polysulfone, the adapters let end users connect off-theshelf single-use systems that feature male coupling inserts on both parts. Being able to combine differing inserts provides a reducing option when users need to transition between tubing with diameters ranging from ¹/ to ½ in.
The MPC and MPX ¾ and 1½-in. sanitary inserts allow connections to equipment or single-use systems that feature sanitary fittings.
Colder Products Co.
1001 Westgate Dr.
St. Paul, MN 55114
(800) 444-2474
