High-performance CD couplings
June 7, 2012
The Series A1C highperformance CD couplings are designed for demanding servomotor and motion-control applications
The Series A1C highperformance CD couplings are designed for demanding servomotor and motion-control applications. The couplings feature high torsional stiffness, high dynamic-load capacity, and precise positioning under highspeed reversing loads without fatigue for reliable 24/7 operation. These zerobacklash couplings handle reversing loads and provide smooth operation at high speeds.
The devices are designed with improved clamp-style hubs for handling larger shafts and higher torque, as well as good shaft engagement. Shafts have increased clamping strength, eliminating the need for keyways for a cleaner, better-balanced design. The couplings come in six sizes and torque capacities range from 40 to 564 Nm with speed ratings from 6,700 to 15,000 rpm, depending on the model.
Zero-Max
13200 Sixth Ave. N
Plymouth, Minnesota 55441
(800) 533-1731
www.zero-max.com
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
