Micropump weighs just 18 gm
The Type NMP05 diaphragm micropump, for sampling air and gases, combines high performance with precision miniature packaging to deliver reliable operation for a range of battery-operated equipment applications
June 7, 2012
The Type NMP05 diaphragm micropump, for sampling air and gases, combines high performance with precision miniature packaging to deliver reliable operation for a range of battery-operated equipment applications. The miniature pump measures 17 × 26 × 31 mm and weighs around 18 gm.
The pump features a bolted-on pump head to ensure gas tightness, as well as a molded diaphragm with structured surface for maximum end vacuum and extended lifetime. A variety of brush-type dc motors or premium ironless-core dc and bldc motors with integrated electronics featuring low EMI/RFI can be specified. A valve system promotes low aerodynamic loss and optimized flow. The pump’s oilless operation allows for uncontaminated flow of the pumped medium. The pumps can achieve 450-ml/min flow rates, continuous vacuum to 15.2-in. Hg, and continuous pressure to 2.2 psig.
KNF Neuberger Inc.
2 Black Forest Rd.
Trenton, NJ 08691
(609) 890-8600
www.knf.com/oemicro.htm
© 2012 Penton Media, Inc.
