Cabinet coolers for enclosures
June 7, 2012
Dual High-Temperature Cabinet Coolers purge and cool electrical control panels in environments up to 200°F (93°C). Air as cool as 20°F (–7°C) eliminates high-temperature malfunctions and protects sensitive electronics in hot, dirty locations
Dual High-Temperature Cabinet Coolers purge and cool electrical control panels in environments up to 200°F (93°C). Air as cool as 20°F (–7°C) eliminates high-temperature malfunctions and protects sensitive electronics in hot, dirty locations.
The Coolers’ vortex tube turns regular compressed air to cold air without using refrigerants. The unit mounts through a standard electrical knockout, while maintaining the enclosure’s NEMA-12, 4, or 4X rating. Systems with thermostat controls minimize compressed-air use by keeping the enclosure at ±2°F of the temperature setting. A drain-filter separator keeps moisture out of the electrical enclosure. The Coolers are available with 4,000, 4,800, and 5,600 Btu/hr cooling capacities.
Exair Corp.
11510 Goldcoast Dr.
Cincinnati, OH 45249
(800) 903- 9247
www.exair.com/dualhtcc.htm
© 2012 Penton Media, Inc.
