Stainless-steel sliding plate cover
May 10, 2012
Gorplate stainless-steel protective covers provide an additional level of protection not available with conventional fabric bellows
Gorplate stainless-steel protective covers provide an additional level of protection not available with conventional fabric bellows. The stainless-steel plates and monofilament connections protect linear rails, ways, and machine elements from damage. The unidirectional monofilament plate connection provides uniform plate expansion in a low profile design.
Cover depth is approximately 1 in. with the capability of cover widths as narrow at 7 in. The system can be used horizontally or vertically, and is an alternative to sliding-plate systems that are prone to locking. Benefits of the system include resistance to heavy chip load and weld splatter, and excellent extended to retracted ratios.
A&A Mfg. Co. Inc. Gortite Div.
2300 S. Calhoun Rd.
New Berlin, WI 53151
(800) 298-2066
www.gortite.com
© 2012 Penton Media, Inc.
March 18, 2025
March 18, 2025
March 18, 2025
March 18, 2025
