Induction-hardened gear racks
May 10, 2012
Two new versions of Rack Gears feature 1045 carbon-steel construction and induction-hardened teeth for precise operation, high strength, abrasion resistance, and long service life
Two new versions of Rack Gears feature 1045 carbon-steel construction and induction-hardened teeth for precise operation, high strength, abrasion resistance, and long service life. The RGEAH ground rack gear comes without holes or with bottom, side, or side-counterboard tapped holes. The RGEAHL version lets users configure hole machining with bottom, side, or side-counterboard tapped options. Both rack gears have a black-oxide finish, end-face machining, and come in a variety of sizes. The racks are used with pinions (spur gears) to convert rotational motion into linear motion in products such as machine tools, conveyors, hoists, drives, and roller feeds.
Misumi USA
1717 Penny Lane, Suite 200
Schaumburg, IL 60173
(800) 681- 7475
http://us.misumi-ec.com
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
