Check-valve assembly
April 27, 2012
A six-component check-valve assembly, critical to tractors and off-road vehicles, has an improved design and simplified assembly process
A six-component check-valve assembly, critical to tractors and off-road vehicles, has an improved design and simplified assembly process. The valve allows pressurization of the transmission to between 1 and 2 psi for accurate oil evacuation from transmission chambers for shifting gears.
Polyphenylene sulfide was chosen as the most suitable material for the valve body. Rounding out the assembly are a nitrile (NBR) groundrubber check ball, an NBR O-ring, a coil spring, and a PTFE stamped washer. The ball and spring are assembled into the body and the retaining spring welded in place. An outer O-ring and PTFE washer are then put on the valve body.
Minnesota Rubber and Plastics
1100 Xenium Lane N
Minneapolis, MN 55441
(952) 927-1400
www.mnrubber.com
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
