Planetary gearboxes
April 27, 2012
The G30A planetary gearboxes are engineered to complement five different series of the company’s motors, allowing a wide range of output torques and speeds
The G30A planetary gearboxes are engineered to complement five different series of the company’s motors, allowing a wide range of output torques and speeds.
The mounting profile is 30.5 mm in diameter or 38.0 mm square when the optional mounting flange is used. Depending on gear reduction, gearbox lengths vary from 33.7 to 51.2 mm. Fourteen reduction ratios are available ranging from 4:1 to 1296:1 and allow a maximum output load of 2.47 to 8.83 Nm. The gearbox’s sintered- steel planet gears provide high-torque capacity and low audible noise. Single-piece carrier plates with integral gear posts and sun gear can be arranged to achieve many different reduction ratios. The gearbox output is through a 416 stainless-steel shaft and a sintered-metal output bearing.
Pittman
343 Godshall Dr.
Harleysville, PA 19438
(330) 673-3452
www.pittman-motors.com
© 2012 Penton Media, Inc.
