Industrial Ethernet cable
April 26, 2012
An industrial Ethernet cable is now part of the Xtra-Guard highperformance cable line. The new Cat 5e cables are available in unshielded, foil shield, or Supra-Shield foil/braid
An industrial Ethernet cable is now part of the Xtra-Guard highperformance cable line. The new Cat 5e cables are available in unshielded, foil shield, or Supra-Shield foil/braid. The Supra-Shield uses a combination aluminum/polyester/ aluminum foil and tinned copper braid for good EMI performance and flexibility. The cables come –50 to 125°C on FEP-insulated conductors and –50 to 105°C on polyethylene- insulated conductors. The TPE jacket is available in black with standard lengths of 500 and 1,000 ft.
Alpha Wire
711 Lidgerwood Ave.
Elizabeth, NJ 07207
(800) 522-5742
www.alphawire.com/XGIE
© 2012 Penton Media, Inc.
