Safety controller
April 26, 2012
The VAS-2A8L-KE4-8SE stand-alone safety controller is adaptable and easy to install, configure, and run
The VAS-2A8L-KE4-8SE stand-alone safety controller is adaptable and easy to install, configure, and run. The controller provides four redundant safe inputs, two independent safe electronic outputs, runs on standard 24 Vdc, and allows any safe device with dry contacts or electronic safe outputs to be used.
Removable terminals simplify installation and field service and an intuitive drag-and-drop application interface allows quick and easy configuration of complex safety operations. When the configuration is downloaded into the safety controller, documentation is automatically created, and all necessary data is backed up on a memory card.
Pepperl+Fuchs
1600 Enterprise Pkwy.
Twinsburg, OH 44087
(330) 486-0001
www.pepperl-fuchs.us
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
