Thermal fuse
March 23, 2012
The SWTC3 Series thermal fuse features a 20-A rating at 120/250 Vac, making it suitable for use in motors, appliances, cooking and heating equipment
The SWTC3 Series thermal fuse features a 20-A rating at 120/250 Vac, making it suitable for use in motors, appliances, cooking and heating equipment, HVAC, lighting, automotive, commercial coffee equipment, hand dryers, and hot-water appliances.
The thermal cutoffs are designed to provide upper-limit temperature protection by functioning as safety devices to disconnect the current to the heating element in case of a malfunction.
The fuses provide continuous-duty thermal fuse rating and a 125/250-Vac 31.5-A interrupting current. Functioning temperature ranges are from 162 to 464°F with holding temperatures from 117 to 392°F.
Selco Products Co.
8780 Technology Way
Reno, NV 89521
(800) 257-3526
www.selcoproducts.com
