Stainless-steel enclosures
March 23, 2012
The VC4X and VH4X stainless-steel enclosures feature a continuous one-piece silicone gasket that provides an IP66 ingress rating for dusttight and watertight locations
The VC4X and VH4X stainless-steel enclosures feature a continuous one-piece silicone gasket that provides an IP66 ingress rating for dusttight and watertight locations. Available in 304 or 316L stainless steel, the enclosures include standard lift-off door hinges for easy removal of the cover. The standard half-turn door latches are designed for security and include a double-bit insert. Mounting feet can be either in horizontal or vertical directions and an internal/external earth stud is included as standard.
The enclosures can be equipped with mounting DIN rail and terminal block assemblies and can be customized with holes and cut-outs, breather/drains, terminal- block population, various half-turn inserts, gland plates, and operators.
Adalet
4801 West 150th St.
Cleveland, OH 44135
(216)267-9000
www.adalet.com
© 2012 Penton Media, Inc.
