Versatile enclosures
March 23, 2012
The company's line of enclosures offer several new features as standard elements. Standard enclosures are now designed with split rear doors to provide a greater level of security as well as a cleaner look
The company’s line of enclosures offer several new features as standard elements. Standard enclosures are now designed with split rear doors to provide a greater level of security as well as a cleaner look. Customers can use the same key and latch system that’s used in the front, giving them a variety of handle options including a built-in combination lock. Added security and strength is provided by a new twopoint contact system on both the top and bottom of the doors. An ergonomically designed L-shaped hinge system (for front and back doors) makes installation and maintenance a toolless process.
A high-density roof accommodates high-density IT components. The 600-mm-wide enclosures now feature twice as many access holes for cable routing — eight in the new roof — while 700 and 800-mm-wide enclosures have eight holes and rectangular openings on both outer edges for easier cable management.
To further enhance data-center efficiency, optional accessories include split sidewalls, casters, metal baffles, and cable-management products.
Rittal Corp.
1 Rittal Place
Urbana, OH 43078
(800) 477-4220
www.rittal-corp.com
© 2012 Penton Media, Inc.
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
