The VTUB-12 lightweight valve terminal is designed for localized machinemounted applications. The Series is capable of flowing up to 400 lpm or 14 scfm with a maximum pressure of 8 bar or 120 psi.
Constructed with a lightweight, high-performance engineered polymer, the valves are mounted on a durable aluminum profile that is also lightweight. The valve terminal is available as a multipin electrical connection; as many as 35 valves can be installed on one terminal with its single screw and hook method. Available connection cables allow up to a 10-m separation between the controller and the valve.
Festo
395 Moreland Rd.
Hauppauge, NY 11788
(800) 993-3786
