Mixing/diverting ball valve
A three-way mixing/diverting ball valve has a common inlet port that can be open to flow with the outlet ports either individually, for diverting service, or simultaneously, for mixing applications. The miniature ball valve is made in 303 or 316 stainless steels, with a variety of available seal materials. It has excellent corrosion resistance and fluid/temperatures compatibility.
Beswick Engineering Co. Inc.
284 Ocean Rd.
Greenland, NH 03840
(800) 354.5014
