Customizable stringpot
Feb. 10, 2012
The slim and compact SG1 stringpot comes with a 10K-Ω potentiometer that provides a voltage divider output signal proportional to the position of the spring-loaded measuring cable
The slim and compact SG1 stringpot comes with a 10K-Ω potentiometer that provides a voltage divider output signal proportional to the position of the spring-loaded measuring cable. It has a stroke range of 80 in. (a 120-in. version is coming), and operates at 0 to 160°F.
The SG1, constructed with a rugged polycarbonate body, a high-cycle plastic hybrid potentiometer, and a durable spring-loaded stainless-steel measuring cable, has been designed for tight spaces, complete with a generous measuring cable misalignment and free release tolerance.
Electrical connection options include the M12 connector, a 40-in. pigtail, or solder terminals directly on the SG1 pot. To withstand wet IP67 environments, the M12 connector and pigtail options provide an O-ring-sealed cover. Additionally, the M12 connector option comes with a field-installable mating plug and a 13-ft cordset is available.
Celesco Transducer Products
20630 Plummer St.
Chatsworth, CA 91311
(800) 423-5483
www.celesco.com
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
