The U8030 Series is the only triple-output power supply in its class with front-panel programming, which saves time and reduces complexity by letting users set and control key output parameters without extensive programming knowledge. The dc supplies are suitable for margin tests, burn-in or reliability tests, and general electronics manufacturing.
The supplies’ three channels can be controlled individually or simultaneously with just a press of a button (all on/off), delivering up to 375 W (total) to multiple devices or points. A screen shows voltage and current readings simultaneously.
The U8030 Series includes overvoltage and overcurrent protection to ensure the integrity of the device-under-test and to protect the power supply.
Agilent Technologies Inc.
5301 Stevens Creek Blvd.
Santa Clara, CA 95051
(877) 424-4536
www.agilent.com/find/U8030
