The 3G3AX-MX2-EIP-A EtherNet/IP interface communicates network slave capabilities to 3G3AX-MX2 ac drives. The front-panel mounting interface is equipped with Safe Torque Off (STO) and an External Device Monitoring output circuit (EDM). Flowchart drive programming with PLC-like functionality and simple positioning in open loop makes the interface suited for simple single-axis-positioning applications. The drives come in 230 and 460-V voltages and power ratings of 1/8 to 20 hp.
Omron Industrial Automation
One Commerce Dr.
Schaumburg, IL 60173
(866) 886-6766
www.omrom247.com
Aug. 29, 2024
Aug. 28, 2024
