Hazard warning lights
Feb. 10, 2012
The Series 56 Flasher is an LED hazard warning light with pulsations of ultrabright illumination with 180° of visibility
The Series 56 Flasher is an LED hazard warning light with pulsations of ultrabright illumination with 180° of visibility. Designed to alert users to system malfunction from any angle, the warning light comes in a range of colors, including red, green, blue, yellow, and orange. The front ring can be chrome or plastic, available in a range of colors for unique combinations.
The light’s simple assembly technique accommodates glass or panel assemblies. The pushbuttons operate in extreme conditions from –49 to 176°F and are environmentally sealed to IP67 at the front and IP65 at the rear.
EAO Corp.
98 Washington St.
Milford, CT 06460
(203) 877-4577
www.eao-hmi.com
© 2012 Penton Media, Inc.
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
