Drive belts
Feb. 9, 2012
The Conti-V Varispeed wide V-belt is for variable-speed drives used in the agricultural industry. The Conti-V Multibelt is for use in clutch drives
The Conti-V Varispeed wide V-belt is for variable-speed drives used in the agricultural industry. The Conti-V Multibelt is for use in clutch drives. The heavy-duty timing belts are energy efficient and virtually maintenance-free.
To transmit high power safely, the EPDM-based Varispeed belt has a low-stretch aramid tensile member, is maintenance-free, and temperature stable from –30 to 140°C.
The friction-reduced texture of the Multibelt ensures gentle and silent clutching. The belt’s transverse-cord reinforcement provides high lateral stiffness, and allows for safe transmission of large loads.
ContiTech North America Inc.
136 Summit Ave.
Montvale, NJ 07645
(800) 654-0974
www.contitech-usa.com
© 2012 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
