Gear pump features auxiliary flange
Jan. 18, 2012
The D Series cast-iron pump now features an integrated SAE “A” nine-tooth auxiliary flange for mounting lower pressure aluminum pumps to the rear of the D Series.
The flange lets users mount the company’s SNP2 pump to its through drive, eliminating the need for another pump drive. The flange’s independent shaft seal isolates the D Series hydraulic circuit from the lower-pressure auxiliary pump. This allows operation of two separate hydraulic systems that require increased safety, such as steering and brakes, as well as the ability to leave the auxiliary pump off the machine, to be added later by customer after configuring the machine with their own auxiliary circuits.
Turolla OpenCircuitGear
a member of the Sauer-Danfoss Group
2800 East 13th St.
Ames, IA 50010
(515) 239-6000
