Electric cylinders
Jan. 18, 2012
The Electric Cylinder Series, designed for harsh/dirty industrial applications, features ground and hard-chrome-plated actuator tubes that house Acme and ball screws.
The Electric Cylinder Series, designed for harsh/dirty industrial applications, features ground and hard-chrome-plated actuator tubes that house Acme and ball screws. The completely enclosed cylinders are suited for outdoor/off-road industrial applications including military use.
The cylinders feature a direct power source, no hoses, no leaks, a smaller footprint, high repeatability, and precision. Configurations include in-line actuator, direct drive, and right-angle drive.
The ILAs offer no reduction as they are designed to have a motor or gear reducer directly coupled to provide fast, precise operation and/or higher duty cycles. Features include a ½ to 10-ton load-capacity range; are ball-screw actuated; keyed or unkeyed actuator tubes; and standard trunnion-pin mounting for use with servomotors and planetary gear reducers. The DD version has a ½ to 20-ton load-capacity range; ball or Acme-screw actuated; and a worm-gear powertrain. The RAD model is for applications that require reduced rpms to move a lot of weight. It has the same features of the DD with a second stage of worm-gear reduction to provide higher thrust at lower speeds. The reducer and motor can be mounted in eight different positions.
Nook Industries Inc.
4950 E. 49th St.
Cleveland, OH 44125
(800) 321-7800
