Hydraulic cylinders
Dec. 8, 2011
The MH and TAS Series cylinders deliver more reliability in heavy-duty industrial operations. The medium-pressure MH Series are rated for 675 to 1,500 psi (depending on bore size)
The MH and TAS Series cylinders deliver more reliability in heavy-duty industrial operations. The medium-pressure MH Series are rated for 675 to 1,500 psi (depending on bore size). The TAS Series steel pneumatic cylinders are rated for 250-psi air and 400-psi hydraulic (with TH option). Both models are available in bore sizes 1.50, 2, 2.50, 3.25, 4, 5, 6, and 8 in.
Features include a heavy-duty rod wiper, seals, wear band, and chrome-plated ID tube. Rod locks, stop tubes, center supports, stainless-steel piston rods, and high-impact pistons are also available. Accessories include clevis pins, mounts, and alignment couplers, with up to a 5-in. thread size.
TRD Manufacturing Inc., a Bimba Co.
10914 N. 2nd St.
Machesney Park, IL 61115
(815) 654-7775
www.trdmfg.com
© 2011 Penton Media, Inc.
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
