Heavy-duty cylinders
Dec. 8, 2011
The double-acting Model 18D and 18SD heavy-duty air cylinders come in both stud and universal mounts
The double-acting Model 18D and 18SD heavy-duty air cylinders come in both stud and universal mounts. Both model have 1.12-in. bores and nitrile seals rated for 180°F and 150-psi maximum. The cylinders are hard-coated anodized aluminum with zinc plated nuts and lockwashers, and feature chrome-plated stainless-steel rods with brass pistons and black-oxide-finished end covers. Designed with standard bumpers at both ends, the cylinders have low friction U-cup seals with moly lubrication.
Air Engineering and Supply
2719 East Franklin Ave.
Minneapolis, MN 55406
(800) 332-4181
www.airengr.com
© 2011 Penton Media, Inc.
