Detented shuttle valve for high pressures
Dec. 8, 2011
The 375 detented shuttle valve is for high-pressure applications with system pressures up to 5,000 psi
The 375 detented shuttle valve is for high-pressure applications with system pressures up to 5,000 psi. The 0.375-in.-diameter shuttle valve has a poppet that latches at either seat to close off the emergency port or the normal port. Weighing only 12 gm, the valve is available in a metal seat version, as well as one with a polymeric seat for applications requiring zero leakage.
The Lee Co.
2 Pettipaug Rd., Box 424
Westbrook, CT 06498
(860) 399-6281
www.theleeco.com
© 2011 Penton Media, Inc.
