A wide selection of surface-mount, automotive-blade fuse clips secure fuses in place even after multiple insertions. The low-profile clips are made from brass with tin-nickel plate and are suited to high-density applications. The devices come in vertical, horizontal, and thru-board blade entry types and accept standard style ATO and ATC fuses; low-profile Mini #891 or ATM-LP fuses; and mini and ATM Series of mini auto fuses. Voltage rating is at 500 Vac and 15 to 30 A.
Keystone Electronics Corp.
31-07 20th Rd.
Astoria, NY 11105
(800) 221-5510
www.keyelco.com
