LED lighting rated for high-pressure, high-temperature wash downs
Nov. 3, 2011
LF1D LED lighting units with an IP69K rating can be used in environments requiring protection from dust, as well as the ability to withstand high-pressure and high-temperature spray-downs.
The light strips are the brightest in their class at 67.2 lumens/W (wide) and 66.6 lumens/W (slim). The lights retain 70% of their initial luminance at 50,000 hr. The units, with die-cast aluminum housings and stainless-steel front covers, come in cool white (5,700°K), slim (10 × 1 LED array), or wide type (7 × 2 LED array) with 24-Vdc voltage.
IDEC Corp.
1175 Elko Dr.
Sunnyvale, CA 94089
(800) 262-4332
