Long-stroke gripper
Nov. 3, 2011
With multitooth jaw guidance, the PHL gripper ‘s roller bearings and profiled rail guidance give it a 25% higher degree of efficiency.
With multitooth jaw guidance, the PHL gripper ‘s roller bearings and profiled rail guidance give it a 25% higher degree of efficiency. The guiding carriage of the gripper fingers have ball bearings, which minimizes friction and evenly distributes forces. A permanently lubricated and sealed jaw guide boosts the bearing capacity of the gripper and reduces wear.
The gripper comes in five sizes with piston diameters between 25 and 63 mm and three strokes per size (covering the entire range of 30 to 160 mm) are available.
Schunk
211 Kitty Hawk Dr.
Morrisville, NC 27560
(800) 772-4865
