Proportional valves
Nov. 3, 2011
A new line of proportional valves are for sophisticated electrohydraulic axis-control applications. AxisPro valves support centralized and distributed-control architectures in
A new line of proportional valves are for sophisticated electrohydraulic axis-control applications. AxisPro valves support centralized and distributed-control architectures in woodworking, wind-turbine, metalforming, plastic-molding, and pulp and paper applications. Programmable onboard electronics and integral spool LVDT sensors provide precise and responsive axis control. The valves work with a CANopen fieldbus and a range of pressure and temperature sensors. Initial products are ISO-3 and ISO-5 sizes with rated flows of 40 and 100 lpm and dynamic bandwidths of 150 and 100 Hz, respectively. Pressure ratings are 350 bar, except 250 bar for the T-port.
Eaton Corp., Hydraulics Group
14615 Lone Oak Rd.
Eden Prairie, MN 55344
(952) 924-7992
www.eaton.com/hydraulics
© 2011 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
