Linear actuator for automation
Nov. 3, 2011
The M-272 linear actuator for automation is based on a maintenance-free PILine ultrasonic ceramic motor. With velocities of up to 200 mm/sec
The M-272 linear actuator for automation is based on a maintenance-free PILine ultrasonic ceramic motor. With velocities of up to 200 mm/sec, these drives are fast, compact, readily integrated, and self-locking at rest with zero heat generation, eliminating the need for an additional motor brake.
The closed-loop linear drive combines motor, actuator, linear encoder, guiding system, and brake functionality in a single package.
Features/advantages include a travel range 50 mm; 5-µm resolution with integrated linear encoder; high speed and dynamics for fast settling; no energy consumption, and OEM driver electronics for ultrasonic motors are available.
PI (Physik Instrumente) L.P.
16 Albert St.
Auburn, MA 01501
(508) 832-3456
www.pi-usa.us
© 2011 Penton Media, Inc.
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
