Vortex tubes
Oct. 21, 2011
Vortex tubes provide a low-cost, maintenance-free solution to industrial spot-cooling problems
Vortex tubes provide a low-cost, maintenance-free solution to industrial spot-cooling problems. Using the characteristics of rapidly rotating air, the tubes convert ordinary 80 to 100-psig compressed air into a stream of air whose temperature can be adjusted to be as cold as –50°F (–46°C). The corrosion-resistant stainless-steel tubes have no moving parts.
Exair Corp.
11510 Goldcoast Dr.
Cincinnati, OH 45249
(800) 903-9247
www.exair.com/vt.htm
© 2011 Penton Media, Inc.
