The HS Series slewing-ring bearings offer high load and thrust capacity for their size. The bearing’s outside diameters range from 20 to 47 in. (500 to 1,200 mm), and feature four-point contact in deep groove gothic arch raceways.
A rectangular cross section gives the bearings greater stiffness, which reduces distortion and allows lower internal diametral clearance. The bearings are available with internal gearing, external gearing, or no gearing. Standard features include two fittings for lubrication and integral seals to protect against contamination.
Kaydon Corp.
Bearings Div., 2860 McCracken, Box 688
Muskegon, MI 49443
(231) 755-3747
www.kaydonbearings.com
