Insidepenton Com Images Rotary Servopneumatics
Rotary servopneumatics
Sept. 29, 2011
The DSMI-B servopneumatic swivel module provides rapid rotary movements at angles of up to 270°. With an electronic controller, it gently brakes the swivel drive to a stop, even at high speeds
The DSMI-B servopneumatic swivel module provides rapid rotary movements at angles of up to 270°. With an electronic controller, it gently brakes the swivel drive to a stop, even at high speeds. With this soft-stop function, it moves loads up to 300 kg, and can reduce cycle times 30% and eliminate the need for shock absorbers. It can also freely position loads to within 0.2 mm and control force within 5%.
Festo
395 Moreland Rd.
Hauppauge, NY 11788
(800) 993-3786
www.festo.com/us
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
