The UTCSK camera slider is for small-to-medium lightweight DSLR cameras and lenses. The unit comes in two standard lengths of aluminum track: 1,000 and 1,500 mm. For easy tripod mounting, ¼-20-in. threads are located at the center and on both ends of the track. The anodized aluminum wheel plate with linear guide wheels includes a ¼-20-in. camera thumbscrew for use with or without a ball-head mount. To protect the camera, two adjustable end stop blocks with nylon screws are standard.
Bishop-Wisecarver Corp.
2104 Martin Way
Pittsburg, CA 94565
(888) 580-8272
www.utcsk.com
