Insidepenton Com Images High Temperature Bearings
High-temperature bearings
Sept. 29, 2011
DryLube bearings eliminate the need for grease relubrication and perform maintenance-free over a wide temperature range, making them suitable for hostile and extreme temperature applications
DryLube bearings eliminate the need for grease relubrication and perform maintenance-free over a wide temperature range, making them suitable for hostile and extreme temperature applications.
The bearings are filled with a dry lubricant based on graphite or molybdenum disulfide and a resin binder. The lubricant is injected into the bearing’s free space, bonded to the cage, and cured until it solidifies. This dry lubricant maintains a thin film on the bearing’s raceways and rolling elements to protect against metal-to-metal contact and any potential damage caused by solid contaminants.
The bearings provide effective lubrication for temperature applications up to 350°C, achieve higher speed capabilities than their standard graphite-cage counterparts, and exhibit minimal lubricant loss over time.
SKF USA Inc.
890 Forty Foot Rd., Box 352
Lansdale, PA 19446
(800) 440-4753
www.skfusa.com
© 2011 Penton Media, Inc.
