Insidepenton Com Images Case Hardened Rack
Case-hardened rack
Sept. 29, 2011
The Performance Class Rack is a case-hardened rack series that is an integral part of the company’s new high-performance linear system, which partners the rack with gearbox/actuator and pinion for system efficiency and optimal performance
The Performance Class Rack is a case-hardened rack series that is an integral part of the company’s new high-performance linear system, which partners the rack with gearbox/actuator and pinion for system efficiency and optimal performance.
Four series of rack systems are available: Value Class, Smart Class, Premium Class, and Performance Class. The most economical, the Value Class, is for low-duty applications. Smart Class offers mounting flexibility, and Premium Class is for high-duty applications. The Performance Class is case hardened for optimal performance.
The Performance Class rack is available in two options — Performance (standard hole pattern) and High Performance (optimized hole pattern for high feeding forces). The hardening process provides strength at the tooth root of the rack, making the rack resistant to high stresses and allowing higher feeding forces to be transmitted.
Wittenstein Inc.
1249 Humbracht Circle
Bartlett, IL 60103
(888) 534-1222
www.wittenstein-us.com
© 2011 Penton Media, Inc.
In the rapidly evolving landscape of industrial manufacturing, reliability, productivity, and worker safety take precedence. However, traditional connectivity approaches often...
June 6, 2025
Amidst the rapid evolution of electronics manufacturing, reliability, productivity, and worker safety remain paramount concerns. Yet, traditional connectivity methods often falter...
June 6, 2025
While many within the industrial manufacturing sector grasp the importance of smart manufacturing for optimizing processes, boosting productivity, and future-proofing operations...
June 6, 2025
For electronics manufacturers grappling with formidable challenges, navigating the path to success requires adapting to the dynamic landscape of the industry. How can electronics...
