Bulk power dc/dc supply
Sept. 8, 2011
Designed to deliver bulk power to 54‑Vdc distributed-power applications, the D1U4CS front-end 2,100-W dc/dc power supply is 93% efficient at half load power.
Designed to deliver bulk power to 54‑Vdc distributed-power applications, the D1U4CS front-end 2,100-W dc/dc power supply is 93% efficient at half load power. With a floating output, users can wire the power supply in a 54-V configuration for data centers or –54-V configuration for telco central-office environments. A 5-Vdc, 0.75-A standby output is also provided. Capable of operating from –40 to –72 Vdc, the 1U unit has a power density of 24.3 W/cu in. Two internal fans provide forced air cooling.
The D1U4CS is N+1 redundant, hot-swappable, and capable of droop current sharing and has a comprehensive set of power control, logic signaling, and operational status functions. The supply automatically recovers from overcurrent and overtemperature faults.
Murata Power Solutions Inc.
11 Cabot Blvd.
Mansfield, MA 02048
(508) 339.3000
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
