Precision regulator
Sept. 8, 2011
The miniature precision regulator provides highly accurate air pressure control in limited-space applications.
The miniature precision regulator provides highly accurate air pressure control in limited-space applications. This precision-machined regulator features an output pressure range to 100 psi, high-flow rate of 4.5 scfm, and a maximum supply pressure of 250 psi.
Tight design tolerances minimize vibration, allowing the regulator to remain stable under changing operating conditions.
Pneumadyne Inc.
14425 23rd Ave. N
Plymouth, MN 55447
(763) 559-0177
