Engineered for extreme high-pressure, high-impulse spiral-wire hydraulic hose, GlobalSpiral couplings feature a “bite-the-wire” crimp for improved coupling retention, and can be used with the company’s MegaSys four and six-spiral wire hoses up to 8,000 psi.
The coupling’s two-piece, no-skive design reduces assembly time, labor, fabrication errors, and contamination of the fluid-power system. The work area stays clean, and the odors and dust normally created by skiving are eliminated.
The couplings are available in over 30 thread configurations, including SAE, DIN, BSP, Komatsu, and JIS. They have been tested to industry-leading 1,000,000 impulse cycles at 250°F (121°C).
Gates Corp.
Box 5887
Denver, CO 80217
(800) 366-3128
