Turcon M12 sealing material is specifically for seals that operate at a wide range of temperatures, pressures, and operating speeds. The material’s composition makes it suitable for use with all types of hydraulic fluid. The seals operate in –40 to 200°C, pressures up to 50 MPa, and operating speeds up to 15 m/sec. The material displays a wide range of strengths; for example, low wear in large cylinders, low friction in high-frequency motion, which is typical for hydraulic spring cylinders, and high wear resistance at high operating pressures encountered in machine tools and presses.
Trelleborg Sealing Solutions
2531 Bremer Rd.
Ft. Wayne, IN 46803
(260) 749-9631
