Mobile lube system
Aug. 25, 2011
A new mobile lubrication system provides storage and dispensing of lubricants, cutting oils, bearing oils, hydraulic fluids, transmission fluids, and engine oils for plants requiring lubrication maintenance at multiple locations over a large area
A new mobile lubrication system provides storage and dispensing of lubricants, cutting oils, bearing oils, hydraulic fluids, transmission fluids, and engine oils for plants requiring lubrication maintenance at multiple locations over a large area.
Delivered on a pallet for placement by a forklift anywhere within a plant, the system includes two 50-gallon and two 25-gallon steel containers with PVC sight gages. Air-operated piston pumps on top of each container provide a 5:1 pumping ratio, while filters on the side of each container remove any dirt or small particulates. A ball-valve manifold, attached to the compressor in the center of the system, allows users to turn on one, two, or all four of the pumps at any time. Start-up is quick and easy with the system’s onboard gas-operated air compressor.
At the dispensing end, the system provides retractable hose reels with metered dispensing-control handles that show how much fluid has been dispensed. A large steel toolbox underneath the reels is for storage of tools, greases, rags, etc.
The IFH Group Inc.
3300 E. Route 30
Rock Falls, IL 61071
(800) 435-7003
www. ifhgroup.com
© 2011 Penton Media, Inc.
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
