Brushless servosystem
Aug. 25, 2011
The brushless ServoNOW servosystem for single-axis applications limits programmability and uses simple positioning and speed-control applications, reducing overall setup and installation
The brushless ServoNOW servosystem for single-axis applications limits programmability and uses simple positioning and speed-control applications, reducing overall setup and installation.
A simplified indexing-type command structure programs all input and output functions. Analog inputs can be selected and set up to control the position or velocity.
The device features a closed-loop brushless servomotor with built-in driver, controller, magnetic encoder, and 110/230-Vac universal power supply. Four programmable digital inputs and outputs, analog I/O (0 to 10 Vdc or 4 to 20 mA, 12 bit), and position resolution of 4,096 counts/rev is included. Five 34 frame models are available with different variations of high speed (6,900 rpm) and high torque (310 lb-in.) features.
Bison Gear & Engineering Corp.
3850 Ohio Ave.
St. Charles, IL 60174
(800) 282-4766
www.bisongear.com
© 2011 Penton Media, Inc.
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
